Remove Y Pipe
Old Sep 6, 2021 | 03:57 PM
Richard Gallant's Avatar
Default Remove Y Pipe
Anyone have a good write up on the process or any gotcha's. Mine is cracked in the usual place just below the flange.
I figured on dropping it and getting it welded, while I wait for the the new gaskets and stud kit.
As far as I can tell the process is :
  1. Drop the cross member
  2. Remove the O2 Connectors
  3. Support the exhaust
  4. Undo the Y pipe to manifold bolts
  5. Undo the rear 2 bolts
  6. ease the exhaust down and out to one side or the front
I am missing anything ?
Old Sep 6, 2021 | 04:08 PM
The Deputy's Avatar
When you get to the manifold nuts, go after the passengers side first. One stud/nut is a bit tricky to get an extention and socket on, kind of a blind removal. The drivers side are easily accessed, so save the best for last.
Old Sep 6, 2021 | 04:26 PM
@The Deputy Those 6 little buggers at the Y pipe to manifold I have down pat, but that one is in a just nasty place.
Old Sep 6, 2021 | 07:11 PM
Brandon318's Avatar
Did this same thing a few months ago. Night and day difference in sound when you get those flange cracks welded. The process you have looks great! A couple 12" extensions and a wobble make the job more comfortable upside down, but not essential.
Old Sep 6, 2021 | 08:14 PM
Tumbler's Avatar
Just removed mine for a gasket swap. I snapped like 5 studs on the headers to y-pipe connections. Take it from me wire brush the threads super clean, soak the studs in the penetrating oil of your choice, and use impact tools. I wish you luck.
Old Sep 6, 2021 | 08:45 PM
andino's Avatar
I just did mine a few weeks ago to swap gaskets. I recommend soaking all the nuts with penetrating oil a couple days ahead of time to really let it work in. Mine came off without much trouble and only broke one which i was able to replace with a bolt and nut.
Old Sep 7, 2021 | 01:04 AM
Thanks guys I rtv'd the y-pipe to manifold gaskets about 3 weeks ago so those bolts are easy.
I was not sure if I could get exhaust out with Disco on the ground
Old Sep 7, 2021 | 09:41 AM
wjsj69's Avatar
I got another set of manifolds from parts truck, installed new studs, and replaced them along with the y pipe. I knew the studs were going to break when separating the pipes from the manifolds so I had them ready to go. If you get those nuts off without breaking the studs, consider yourself very lucky (soaked or not).
cybercop
May 5, 2021 04:27 PM
Richard Gallant
Mar 7, 2019 05:04 PM
LR03NJ
Aug 22, 2017 02:33 PM
Savannah Buzz
Feb 16, 2016 10:34 AM
FlyingZebra34
May 12, 2012 05:55 AM
