Removing air intake studs?
Old 09-09-2023, 09:06 PM
neuropathy's Avatar
Default Removing air intake studs?
Is this what’s needed to remove the air intake studs? It doesn’t seem the air intake brackets/pipes bend enough to slip them off the studs and I don’t want to break anything.
Put this socket on and remove as if it was a bolt or are the threads backwards on a stud so it would be removed wrenching the opposite direction?
Anyone know what size/threading bolts should be used instead? Pretty close to having the upper intake removed to install the coil packs - might end up dealing with the valve covers and valley pan gasket/seals too. Thanks
Old 09-09-2023, 09:41 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
Install 2 nuts back to back & use 2 open end wrenches to tighten them against each other, then remove like it's a bolt.
The following 3 users liked this post by Best4x4:
mollusc (09-10-2023), neuropathy (09-10-2023), Richard Gallant (09-09-2023)
Poway
Range Rover L322 (3rd Gen)
08-24-2023 06:59 PM
greenrovey
04-07-2021 03:16 PM
Richard Gallant
04-17-2020 10:20 AM
chavhater
04-03-2018 07:18 AM
xxjtvxx
08-24-2016 08:11 PM
Quick Reply: Removing air intake studs?
