Removing O2 Sensors
Old Jul 13, 2007 | 10:20 AM
okdiscoguy's Avatar
Default RE: Removing O2 Sensors
If you didn't cover the connectors with heat shrink, dab some liquid electircal tape on them or you will have problems later. Water gets in there and can track through the wires, corroding all the way down...
Old Jul 19, 2007 | 05:48 PM
bgalway's Avatar
7th Gear
Having trouble getting the right pre cat out. Used pb blaster and an O2 sensor socket...no dice... I have a hand held torch but I can only get at the top of the cat from the top. Torch won't stay lit....... there must be another way, will heating the cat from the bottom be just as effective?
Old Jul 19, 2007 | 11:42 PM
wvcox1's Avatar
You might try MAPP gas on your torch, lot more powerful & heating @ that angle might do the trick
Best of luck to you!
Regards,
Walter
Old Jul 20, 2007 | 07:01 AM
EVN137's Avatar
I used a long flat blade screw driver to undo the 02 connector clips since it is so hard to reach ( left precat sensor ). Pry the clips one at a time then yank on the cable. Make sure you are turning ( unscrewing ) the 02 the right way since you are looking at it from the opposite side when you're under the truck.
Ed
DiscoRover007
Mar 4, 2015 07:10 AM
chicane
Jul 8, 2014 09:57 AM
chicane
Mar 2, 2014 09:12 PM
Benhamtroll
Apr 21, 2005 10:18 PM
