Replace the coil packs preventatively or not?
Old Mar 17, 2022 | 12:22 PM
SWM's Avatar
SWM
Default Replace the coil packs preventatively or not?
I'm going to tackle the wires and plugs using the intake off method. Yes, Yes, I've read the threads on doing it without pulling the intake, coat hangers, wife's little hands, etc., etc. My fat hands can't get it done and I'm doing a bunch of things anyway while it's off.
Question is, should I preventatively replace the coil packs while I've got it all off? I'm not getting any faults or rough idle, etc. Just replacing based on age but engine only has 79K miles.
I want black wires so I'm between the Kingsbourne 8mm or the 7mm Magnecore.
Plugs, I went with NGK Laser Iridium
Coil Packs - I assume I would go with OEM BOSCH units unless someone can suggest a better replacement
Old Mar 17, 2022 | 12:26 PM
Harvlr's Avatar
Personally it’s not an item I’d change on spec. If one fails I don’t think it will leave you stranded, and new ones aren’t necessarily better than your old tried and true units.
Old Mar 17, 2022 | 02:15 PM
PickleRick's Avatar
After having to replace them a month after doing the heads I'd say yes bur she's a 1999 with 240k and counting we've owned 9 months or so and it's a DD.
We knew zero about the service history.
Cheap Amazon replacements did the trick. I normally don't use cheap electronic, like the maf (used vw part number) but these seem to get great long term reviews.
Old Mar 17, 2022 | 08:57 PM
Brandon318's Avatar
I have a set of Magnecor 7mm wires I’ll send ya if you want. They only have about 10k miles on them. I ended up installing the coil pack relocation kit last month which use different length wires. Just pay for shipping and they’re yours
Old Mar 17, 2022 | 10:19 PM
SWM's Avatar
SWM
Wow, you're awesome. I'll send you a pm
toofaroffroad
Feb 24, 2020 08:03 AM
tmckenz
Mar 19, 2015 06:28 AM
Ad!
Mar 21, 2012 06:57 AM
dillhole
Aug 23, 2009 07:53 AM
