Replace driver door lock pin
Old Mar 24, 2015 | 02:01 PM
cammyr01's Avatar
Unhappy Replace driver door lock pin
Is there a write up or video on how to replace the driver side door lock pin? My key will no longer turn in the lock and I am unable to lock the car...
Old Mar 24, 2015 | 02:26 PM
OilPatch's Avatar
Where did you buy the new lock pin? Something is broken on mine and I can turn it but it won't lock
Old Mar 24, 2015 | 04:02 PM
abran's Avatar
Small torx head screw at same level as door handle on inside of door jamb, remove.
Remove door panel. Cut slit in moisture barrier at handle position.
Unclip linkage that connects handle to door opening mechanism.
Push/slide door handle towards front of car to release tab, pull lock side of handle out. Be careful at non lock side and finesse "hook section" out.
You will see just behind the lock there is a broken pin with a barrel pin perpendicular holding the broken end of the door lock pin. With a narrow punch, gently tap barrel pin out until enough shows to grab with pliers. Remove pin and replace door lock actuator pin.
Get a working remote so you don't break another pin.
If that pin breaks while the door is locked, there is no other key access to enter the car. The driver side door is your only chance.
Remote will cut down in excessive wear and tear on the pin.
You can make a new stronger pin out of a large nail. I forget the exact size, but you will have to grind the nail head to have the same "mace/cross" head to fit into the actuator.
Old Mar 25, 2015 | 02:19 PM
cammyr01's Avatar
I believe Atlantic British has them and perhaps Rock Auto and/or Parts Geek.
Not sure if I will purchase one or try to make one using a nail.
Old Mar 25, 2015 | 02:33 PM
cammyr01's Avatar
YOU ROCK!
I would love love love to get a new remote, unfortunately don't have the barcode and the original remote is crackedopen, I understand there may have been a code inside, alas there is nothing...
Old Mar 25, 2015 | 03:50 PM
OffroadFrance's Avatar
Originally Posted by cammyr01
YOU ROCK!
Try this vendor they may help you with your problems.
http://www.keylessride.com/
Old Mar 25, 2015 | 11:19 PM
abran's Avatar
^ not sure if you just googled car remotes and pasted it, but that site doesn't have discovery remotes.
RandyH1221GJ
Dec 4, 2013 07:01 PM
Shark59
May 4, 2013 09:33 PM
nicke
Nov 1, 2012 12:34 PM
Fitzpatrick
Feb 17, 2011 09:09 PM
