Replace original D2 radio with am/fm and 2 meter ham
Old May 7, 2020 | 07:50 AM
dcaven's Avatar
Default Replace original D2 radio with am/fm and 2 meter ham
It is time to replace the stereo on my 2003 Discovery 2. Instead of merely replacing the one radio, I would like to install two radios in the same place. One, normal AM/FM with bluetooth, etc. and a second, 2 meter ham. I am wondering if anyone here has done something similar and might have recommendations.
David
Old May 7, 2020 | 08:22 AM
craiglud's Avatar
I am looking at getting my ham radio installed now. I was just looking yesterday and there is a nice place under the pull out cup holder to mount just the head unit of the ham radio (Yaesu 8800). Im thinking of doing that and mounting the core under or behind the dash somewhere and then a hood mount antenna bracket.
Old May 7, 2020 | 08:32 AM
dcaven's Avatar
The way you are doing it is likely the better way. I really want to fit both radios in the current space for the stock one. I already have a CB under the seat and am thinking of mounting a scanner on the dash. I would like to at least try to keep everything organized.
Old May 7, 2020 | 04:49 PM
dparham's Avatar
ive been working on that too lately.. I have my Kenwood D710G i changed my factory radio and picked up some motorola speakers got 4 needed maybe 2 ... thinking of putting the main where dc changer is sitting never to be used... then running the head up to ceiling center where overhead light console is... mounting the mic on dash someplace...
Old May 7, 2020 | 11:23 PM
LeatherBoots's Avatar
I've got a HAM radio install.
You can use the roof center console with a bracket and large washers. to hold it in. I've got my CB and HAM hung from there. Using the radio area is not such a good idea.
Old May 8, 2020 | 06:37 AM
craiglud's Avatar
@LeatherBoots Post a photo of that - I was considering that install also but did not investigate how to hold it up there. The sun roof started acting up yesterday so I may be in there anyway.
Old May 8, 2020 | 07:31 AM
dparham's Avatar
my ham radio came with super sticky mounts im going to use... i dont have the sunroof so ill mount where those controls go.. since its a separate head, the main body will go under seat and it has the mic plug
Old May 8, 2020 | 10:59 AM
Sixpack577's Avatar
Make sure to move the transfer case shifter through all positions before you mount the radio, so that your hand or the shifter don't contact the face of the radio after install.
hrhoward
Apr 11, 2025 09:18 PM
mroceanfront
Aug 26, 2018 11:08 AM
elboy0712
Audio/Visual Electronics
Oct 22, 2017 09:31 PM
XANDER1120
Feb 3, 2012 08:21 AM
amnesia622
Jan 5, 2006 08:11 PM
