Replace smaller SAI vacuum tubing?
I started toying around with the idea of removing the smaller SAI vacuum tubing on the top of the engine and replace it with red HPS 9mm OD/3mm ID silicone heater hose ($30/10 ft). Just to pimp out the engine a little.
I laid out the SAI vacuum tubing to see what goes where and lengths needed. From the picture...
#1 is split off at a "Y" connector at the center of the engine and connects to both SAI control valves and 1 side of the vacuum solenoid valve,
#2 connects to the intake manifold and one side of the vacuum reservoir,
#3 connects to the other side of the vacuum solenoid valve and the other side for the vacuum reservoir.
If I do this, my concerns are extreme heat in the engine bay and also the vacuum pressure in the lines could collapse the silicone heater hose causing a restriction and a snowball effect "effing" up the rest of the system.
BTW... I'm also with the thought process of "If it ain't broke, don't fix it!" More to come...
*Yep... the IAC brackets are on backwards. lol
Dude.
Bad, bad karma comin' your way.
The term "pimp out" don't go wit' da Rovers.
If ya got everything else workin' so well that all ya got ta think 'bout is pimpin' your ride sumthin' else surely gonna go wrong as soon as ya pimp it.
Jus' let it be ... Talk to her nice so she knows ya love her and thank da Lawd that there ain't nuthin' wrong!
JUKE179r (06-17-2020)
Yeah... I guess I shouldn’t have said pimp out the engine. What I meant was a way to ‘improve‘ what’s on the engine.
My SAI vacuum tube rubber connectors are badly worn and torn. I think that is where the majority of my air leaks are coming from. I saw how @cvhyatt added zip ties to keep his rubber connectors connected which I added zip ties also.
SAI Lines
Anybody know where I can get new vacuum lines for the SAI system that are less expensive than the set Atlantic British sells for $500+? I've already replaced everything else in the SAI system except the lines and the check valves on the valve covers and still getting the P1415 code all by its lonesome. Or can I use generic vacuum lines sold at AutoZone, etc.? Vehicle is a 2004 Disco 2 HSE with everything pretty much still stock.
Rovers North about 63.00 https://www.roversnorth.com/parts/wa...r_discovery_ii 4.6 liter
206 https://www.roversnorth.com/parts/wa...ry_air_inj_dii for a 4.0
Richard Gallant (07-01-2020)
