Replace smaller SAI vacuum tubing?
Old Jun 17, 2020 | 03:59 AM
JUKE179r's Avatar
Lightbulb Replace smaller SAI vacuum tubing?
I started toying around with the idea of removing the smaller SAI vacuum tubing on the top of the engine and replace it with red HPS 9mm OD/3mm ID silicone heater hose ($30/10 ft). Just to pimp out the engine a little.
I laid out the SAI vacuum tubing to see what goes where and lengths needed. From the picture...
#1 is split off at a "Y" connector at the center of the engine and connects to both SAI control valves and 1 side of the vacuum solenoid valve,
#2 connects to the intake manifold and one side of the vacuum reservoir,
#3 connects to the other side of the vacuum solenoid valve and the other side for the vacuum reservoir.
If I do this, my concerns are extreme heat in the engine bay and also the vacuum pressure in the lines could collapse the silicone heater hose causing a restriction and a snowball effect "effing" up the rest of the system.
BTW... I'm also with the thought process of "If it ain't broke, don't fix it!" More to come...
*Yep... the IAC brackets are on backwards. lol
Old Jun 17, 2020 | 06:18 AM
mln01's Avatar
Dude.
Bad, bad karma comin' your way.
The term "pimp out" don't go wit' da Rovers.
If ya got everything else workin' so well that all ya got ta think 'bout is pimpin' your ride sumthin' else surely gonna go wrong as soon as ya pimp it.
Jus' let it be ... Talk to her nice so she knows ya love her and thank da Lawd that there ain't nuthin' wrong!
Old Jun 18, 2020 | 01:35 AM
JUKE179r's Avatar
Yeah... I guess I shouldn’t have said pimp out the engine. What I meant was a way to ‘improve‘ what’s on the engine.
My SAI vacuum tube rubber connectors are badly worn and torn. I think that is where the majority of my air leaks are coming from. I saw how @cvhyatt added zip ties to keep his rubber connectors connected which I added zip ties also.
Old Jun 18, 2020 | 06:27 AM
mollusc's Avatar
I don't know what pressures those SAI tubes are subjected to, but typically hoses designed for liquids don't handle vacuum well. Smaller diameter tubes have more rigidity and might not collapse, but they also might, and cause problems.
Old Jul 1, 2020 | 07:03 PM
KarlS+9's Avatar
Default SAI Lines
Anybody know where I can get new vacuum lines for the SAI system that are less expensive than the set Atlantic British sells for $500+? I've already replaced everything else in the SAI system except the lines and the check valves on the valve covers and still getting the P1415 code all by its lonesome. Or can I use generic vacuum lines sold at AutoZone, etc.? Vehicle is a 2004 Disco 2 HSE with everything pretty much still stock.
Old Jul 1, 2020 | 08:19 PM
Richard Gallant's Avatar
Rovers North about 63.00 https://www.roversnorth.com/parts/wa...r_discovery_ii 4.6 liter
206 https://www.roversnorth.com/parts/wa...ry_air_inj_dii for a 4.0
Old Jul 1, 2020 | 11:04 PM
KarlS+9's Avatar
Perfect. Thanks, Richard! As long as I'm living in NC, I have to get it to pass the emissions test. Probably moving to Florida this fall when I get COVID-furloughed from the airlines, so then I won't have to worry about it as much but that SES light is bugging the heck out of me.
Old Mar 26, 2025 | 02:14 AM
ttr55's Avatar
Originally Posted by Richard Gallant
Neither of those works work anymore, and I am lost trying to find replacements for these lines. I'm confident I can "fix" the spot in the middle of the hose that's a clean break, but on the SAI solenoid end, the hose broke clean at the elbow. Any shot you know where they could be found now?
Old Mar 26, 2025 | 12:16 PM
@ttr55 John Cradock in the UK https://www.johncraddockltd.co.uk/wa...-injector.html
Old Mar 26, 2025 | 04:07 PM
ttr55's Avatar
Thank you, I have been hunting the internet and couldn't find that.
kuau
Jan 26, 2019 07:15 PM
04in719
Oct 17, 2017 02:46 PM
srockrae
Jun 29, 2014 07:42 PM
Fast951
Apr 18, 2014 02:12 PM
windowrattler
Jun 11, 2013 12:48 PM
