Replaced ddoor lock actuator
Old Jul 28, 2013 | 10:31 AM
redwhitekat's Avatar
Default Replaced ddoor lock actuator
I tackled it its actually pretty easy to do drivers door
Didn't have to remove door handle just the one 10 mm bolt at bottom of inside door that holds window frame the rest is easy just remove the one Philips and 3 torx screws
My old actuator still kinda works you can hit the lock button twice it licks just won't open
Do I have any use for this part or just pitch it in the garbage ??
Btw for those who live in Ontario Canada lakeshore landrover dealer sells these actuators for 145 new don't bother looking at used ones or even new ones online
Old Dec 14, 2013 | 08:17 PM
tonydliu's Avatar
Need to replace acuator unit (latch& motor assembly) for my 2003 D2, could you list a step-by-step how you did it? I had troubles to remove it out of the door. Some say no need to remove window frame which I didn't...
Brad S1
Jan 23, 2018 09:02 AM
Rover_Hokie
Aug 19, 2014 10:05 PM
marshman 442
Jan 13, 2008 10:15 AM
Brad S1
Dec 5, 2006 05:29 AM
