Replaced head gaskets, now…
Old Feb 22, 2024 | 04:00 PM
Jerryswervin's Avatar
Default Replaced head gaskets, now…
Now I’m getting white smoke from ebrake near center console.
It doesn’t start either. Just a very slow crank.
its an 04, so it doesn’t have the green ground wires.
I made sure all connections are solid and there are no wires left unfastened.
it definitely seems like a grounding issue though.
[edit] is there a way I could fabricate my own ground to the firewall or some other grounding point? Maybe where the head strap is?
Any help is appreciated.
Old Feb 22, 2024 | 06:13 PM
Harvlr's Avatar
I think your issue is that the engine to vehicle ground strap did not get connected. It is trying to find a ground through your ebrake cable. You may need to replace it.
Old Feb 22, 2024 | 06:16 PM
Harvlr's Avatar
From memory, the ground cable attaches to the rear of the left (viewed from the driver seat) head.
Old Feb 22, 2024 | 06:19 PM
yeah it’s attached and in really good shape. Maybe it’s sitting oddly? Or detached from head? I think I’m going to add another ground from the upper manifold to the same stud the strap is attached to.
Old Feb 22, 2024 | 07:02 PM
treicruz's Avatar
This has happened to me twice now, once ground strap below the alternator side of the engine was loose, second time it was dirty. I haven't gotten around to replacing E-brake cable.
Old Feb 23, 2024 | 05:39 AM
Alex_M's Avatar
If you're adding one a!way, I'd run it from? Where the battery !negative connects between the ;artery a!d the fuse box, and connect it to the nearest bolt you can access on the motor.
Old Feb 23, 2024 | 06:36 AM
Problem solved! Actually had the ground point on the alternator mixed up.
Old Feb 23, 2024 | 02:36 PM
Harvlr's Avatar
Good news. Thanks for letting us know.
mdzdisco04
Jun 20, 2019 07:22 PM
RhinoRover
Sep 4, 2017 07:54 AM
timsauto123
Jan 25, 2011 01:52 PM
jayv
Jul 10, 2010 10:21 PM
trey and dianna
Aug 19, 2009 05:11 PM
