Replaced my heater core...it still leaks...
2002 lr disco 2
So I bought a new heater core to replace my leaky one. I was able to get the old out and put the new core in by removing the glove box and a few support pieces, and gently bending some plastic out of the way. In the process of reconnecting the new core I slightly bent one of the pipe ends that go into the core. I bent it back after many tries, it fit in, I bolted the clamps on and it leaks like a ****. Did I ruin the pipe end? If so... is there any way to repair the end or replace the whole pipe without removing the entire dash?! The way those pipes are bent it seems like it would be impossible just to pull one or both out and wiggle a new one in while keeping the dash intact.
thanks for any advice
I’m considering some kind of heat resistant epoxy. Has anyone tried that?
if you do not want to get new tubes...IIRC..about 100$? ...You could weld on some aluminum pipe extension to heater core and use a bit of hose to connect to the original pipes, but you will have to cut the tips off of them as well.... or maybe just run rubber hoses up into engine bay...or get some soft copper tube and make your own...
