Replaced old plugs and wires...
So I replaced the old wires tonight with the Magnecor 8mm wires and the plugs with the Bosch Platinum +4's. Everything went smooth and the rover runs great so far, I can definitely tell that it idles a hell of a lot smoother and it feels like it has more get-up especially going uphill. Only question is this, when I pulled the old plugs, the 4 passenger side plugs (2,4,6,8 I believe) were filthy dirty with what looked like oil or smudge and the drivers side plugs (1,3,5,7) were so dry and brittle that they cracked in half on the way out, well the ceramic casing did at least, should I be concerned?
You have to remove the SAI pipes that run along the back. I used a screw driver covered in electrical tape to pop off wires on the coil.
marsyas
02-25-2021 08:11 AM
Chrisinhouston
05-02-2010 09:15 PM
tommytwotone
10-04-2009 11:14 AM
