Replaced Radiator now another leak
Old 04-12-2020 | 08:13 AM
Extinct's Avatar
Worst part of it is you have to take the oil pan off. Depending on mileage and how bad the rear main seal is I would consider doing the crucifix seals at the same time. Truck has to be jacked up and frame crossmember under oil pan removed. I also drop one side of the tie rod to ease removal. You may want to consider a new water pump and power steering pump gasket and be sure to check your idler pulley bearings while you are at it. I think Oreilly auto parts has a fan wrench you can borrow.
Old 04-12-2020 | 04:50 PM
merebel's Avatar
So you mean this cross member ?
orderofelim
01-09-2020 07:09 PM
orderofelim
01-05-2020 11:02 PM
remember5
12-28-2016 04:34 PM
FlyingZebra34
04-09-2013 10:55 PM
humroot
03-01-2010 03:58 PM
Quick Reply: Replaced Radiator now another leak
