Replacement Fresh Air Intake Plenum
All,
My intake plenum is missing a piece at the end and let me tell you, it is a drag. When it rains, water pours down through the air conditioning setup and if the drain holes are plugged it end up on the carpet. They do plug up, because it also lets leaves in, all of which end up on my fan and cause it to be unbalanced until I empty it out (once a week). I have dealt with this for some time but I am ready for a fix.
I have found OEM intake plenums for about 260, and I found this one for $190: LAND ROVER FRONT WIPER PANEL COVER DISCOVERY 2 II 99 – 04 JAK000010PMA MB | Miami British. Aside from the cheaper price I am wondering whether there is anything to the claim that fiberglass is stronger. Also, I would swear that I read that though part specifies for my 2000 Disco II, it has to be modified somehow; but I can't find that post and am wondering whether I imagined it or whether it might have been for a Disco I. I prefer not to get a used one because our black plastic gets BRITTLE--I have broken and replaced just about all of it.
![](http://miamibritish.com/shop/land-rover-front-wiper-panel-cover-discovery-ii-99-04-mrb/#)
Does anyone have experience with this? I know I could use duct tape, sponges, and chewing gum to fix it but the first one lasted 14 years, give or take, and I would rather just make it look nice. Any input would be appreciated.
Best,
Charlie_V
Best,
Charlie_V
my windshield had to be replaced and they wouldn't do it unless this piece could be replaced because it broke upon removal and is required to protect the edges (most fragile part) of the windshield.
The replaced it and the a pillar trim with brand new pieces and now it leaks as you describe. Can't find where its leaking from though. Seems to fit okay but it did come bare without any of the covers or anything to hold it in place
Rovers North sells all of the parts and gaskets but it is a major expense. The rubber, the foam, the plastic itself... Really adds up. One careless moment with the hood (taking it off to replace the engine) put me in this spot.
I have not had the intake plenum off but there is something over the last opening that leads to the air conditioner that is supposed to keep leaves and debris out. I suspect that is your problem and mine too.
