replacement screw for oil dipstick
Old Jul 26, 2016 | 03:58 PM
DiscoBuckeye's Avatar
Default replacement screw for oil dipstick
When I replaced my valve cover gaskets recently, the screw head was completely corroded. I ultimately had to grind down the head of the screw to get it off. It easily unscrewed when I had the cover off but I have no idea what I did with it to duplicate the threads and replace it. Anyone know?
Old Jul 26, 2016 | 04:26 PM
Jeff Blake's Avatar
Old Jul 26, 2016 | 04:39 PM
Thank you Jeff that is the one. I wish they had a better description. That looks like a screw I can pick up at the local hardware store.
Old Jul 26, 2016 | 04:42 PM
Jeff Blake's Avatar
It probably is - but knowing LR it probably isn't! I gave up trying to find correct replacement hardware for this car and just order the right LR part to save my sanity.
Old Jul 26, 2016 | 04:45 PM
If I did that then I would not have the cool brass nipple on my vacuum hose on the upper intake. After I broke the plastic one.
Old Jul 26, 2016 | 08:33 PM
chubbs878's Avatar
I lost my dipstick screw and tried about a dozen that just would not fit. I went to the junkyard last week and pulled that screw off of every P38 and D2 in the yard. Screwed right in and all is right with the world with 2 extras in my pocket! I think most of us have the brass air compressor fitting at the vacuum Intake after the last tune-up.
MetalMarine
Sep 21, 2014 01:12 PM
bcolins
Jul 27, 2013 12:50 PM
rsr50
Dec 26, 2012 04:17 PM
DeepBlueWater
Jun 14, 2012 04:41 PM
Antmen
May 6, 2010 10:03 PM
