Sponsored by: CARiD
03 range rover, oil on ground, little to no oil on dipstick
Old Dec 25, 2012 | 06:59 PM
rsr50's Avatar
Default 03 range rover, oil on ground, little to no oil on dipstick
03 Range Rover, started car after a few minutes it started smelling real bad, turned off looked under car, puddle of clean oil on ground by front drivers side tire, checked dipstick little to no oil on it. Now I'm afraid to start it, anyone have any ideas as what it could be?
Thank you for any help
rsr50
Old Dec 25, 2012 | 07:04 PM
Shade Tree's Avatar
Sounds like broken/leaking oil cooler line. You are going to have crawl under there and have a look.
Old Dec 25, 2012 | 08:30 PM
Add oil 1/2 quart at a time to get back normal on stick and check for leaks like above.
Old Dec 25, 2012 | 10:11 PM
Sounds like you just had the oil changed and they did not install the oil filter correctly.
BMW engine right? Oil filter is of the cartridge type on the top of the engine.
Where did you have the oil changed?
Whoever it was call them up and have them come out to you, DO NOT do anything, DO NOT add oil, DO NOT start it, call the shop/oil change place.
Old Dec 26, 2012 | 01:19 PM
Rovin4life's Avatar
nah, the bmw motor has issues with the pcv hoses exploding cause the the cyclone separator goes bad. that is if the oil filter housing isn't leaking from the oring. But that is easy to see when you open the hood. basically if the pcv hoses are bad you end up having to put intake gaskets, and the coolant hoses and covers and all new hoses to fix the problem. about a six hour job. you don't need to pull the water pump, just do everything off the back side of the motor. But be careful. the plastic on the back of the intake breaks easily. But they can be had at a bmw dealer. In fact a bmw dealer is way cheaper because the parts are the same.
Old Dec 26, 2012 | 04:17 PM
rsr50's Avatar
called mechanic, he told me to put oil in it to drive down to him if possible. Put oil in it started it and white smoke came pouring out both exaust pipes, please tell me I did not blow my engine, just couldn't afford that right now.
rsr50
kfx4001442
Dec 7, 2012 04:57 PM
RROJ
Jul 24, 2011 07:59 AM
osolupo
May 17, 2010 12:57 PM
Antmen
May 6, 2010 10:03 PM
kcirtap
Sep 26, 2007 09:39 AM
