Replacement Stereo
Old Jul 3, 2013 | 07:14 PM
bcasey's Avatar
7th Gear
Default Replacement Stereo
I have an 01 DII and the tape deck stopped working. I am replacing the stock stereo with a new Alpine with Bluetooth. I wired the new one with the appropriate wire harness, I have power to the unit but no sound to the speaker, not even static or a buzz.
What am I missing? do I need to wire the amp in under the seat? If so, How?
Old Jul 3, 2013 | 07:16 PM
bballjames's Avatar
How did you wire your speakers at all? If not using the amp under the driver's seat, you must run speaker wire from the head unit to the speakers wires where the amp is.
Old Jul 3, 2013 | 07:21 PM
bcasey's Avatar
7th Gear
I purchased the wiring harness that plug into the existing female plugs in the dash. Shouldn't have this tied in the speakers?
Old Jul 3, 2013 | 07:23 PM
bcasey's Avatar
7th Gear
There is a blue and white wire coming of the new stereos wire harness that I believe should go to the amp but not sure how to wire it.
Old Jul 4, 2013 | 06:20 PM
honda50r's Avatar
I picked up a new receiver and am experiencing the same issue. Thinking about running new wires and bypassing everything
Old Jul 4, 2013 | 09:46 PM
MeanSaleen's Avatar
The blue wire is the "remote" wire. Its what sends a signal to the amp to turn "on". You said u bought a harness adaptor? Maybe the aftermarket unit didnt tie in their remote wire to it. Get a long wire and temporarily tie the blue remote wire to the amps remote wire under seat (not sure of the color) and see if it helps
bennyb43
Nov 28, 2015 04:01 PM
amdhotprocessor
Dec 28, 2012 10:12 AM
devildollnyc
Jun 21, 2011 03:33 PM
Crusoe
Apr 8, 2006 10:28 AM
James Vee
Jun 28, 2005 01:04 PM
