Are replacement window regulator glides still available?
Old Feb 23, 2014 | 04:02 AM
  #21
OffroadFrance's Avatar
They are fairly easy to repair even easier with a lathe and workshop. However, new window regulators are very cheap anyway.
https://www.google.fr/search?q=landr...HYDQ&gws_rd=cr
Résultats Google Recherche d'images correspondant à http://www.rjs-land-rover-spares.com/eshop/images/LR006373.jpg
This may help also.
https://landroverforums.com/forum/di...-repair-39684/
Old Feb 23, 2014 | 04:12 AM
  #22
bcolins's Avatar
Originally Posted by ralphobell
I used a washer and nut rivets and then greased the track pretty good. Works like a champ! Make sure you use a tapered flat head screw.
Ralph, I notice you are in Austin as well. if you have your regulator out in the future, I would like to come see how you did this with the nut rivet and tapered flat head screw. Could you PM me? I live in Cedar Park/Austin,....I'd like to come check it out.
Or, perhaps you could do a mock-up of how you put this together if you happen to have an old regulator about (or how about a paint stirrer stick with a hole drilled in it to simulate the regulator arm) and another screw, washer, riv-nut....then shoot some pics for us?
Brian in Austin
Old Feb 23, 2014 | 08:16 AM
  #23
ralphobell's Avatar
Brian in Austin
Brian sent you a PM. I'm in Round Rock actually.
Old Feb 23, 2014 | 11:44 PM
  #24
eitydeuce's Avatar
Check this one out, may be helpfull. https://landroverforums.com/forum/ge...e-right-56542/
Old Apr 6, 2016 | 12:38 PM
  #25
bcolins's Avatar
Originally Posted by Bryan H
Ralph is on the right track. I use a metal washer inside the track with a poly washer on the outside, all held together with a panhead bolt and locknut. Can be purchased at the hardware store for less than $1. Mine have worked well for several years.
Bryan, could you give us some details on this fix. Maybe a pic of the bits you used?? Ive tried several of these DIY fixes,...no luck yet. (other than the no longer available LRD2ME snap in rollers that worked perfectly)
RedAustinIX
Aug 10, 2020 11:43 PM
Savannah Buzz
Apr 1, 2012 12:26 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
