Replacing CDL switch
Old Sep 12, 2020 | 03:28 PM
wes_in_va's Avatar
Default Replacing CDL switch
The CDL switch on '04 Disco 2 has gone wonky. I've pulled the console so I have "access"to the transfer case (and I use the term access loosely, of course) and the switch. I have it unplugged but damn if I can get it out. It seems like that my 19mm socket just won't sit down on it enough to remove it. A deep well socket might work but there's no room for a deeper socket in there.
I've tried crawling under the truck and accessing it from the side with an open end wrench but I'd need several more joints in my arm to make that work.
Any suggestions??
Old Sep 12, 2020 | 07:51 PM
Richard Gallant's Avatar
Which switch failed, the CDL one I believe is just a light, the Hi low is important but you can get that on from underneath
Old Sep 13, 2020 | 10:00 AM
ahab's Avatar
Here's how I fixed mine for $10 with a DMM and the ETM. Both the Low Range and Diff Lock switches were bad so I went to the junkyard and got a couple extra hazard switches with connectors, and cut this section of harness in the red circle out of another 04 Disco.
I soldered the wires back together with the plugs at each end, creating a plug and play intermediate harness that I could connect in between the existing plugs in my truck. I simply pulled them apart and plugged this in between them. I soldered in a section of LAN cable inline with the wires that ran to the TC switches and then ran it up to the dash. You don't need to use this section of harness that I made. You could identify the TC switch wires and solder jumpers into the harness in your truck but I don't like messing with the factory harness and wanted something that was completely removable to put the truck back to stock with no trace of the mod, so I made the harness.
I soldered the two hazard switch plugs to the other end of the LAN cable and swapped the button covers with the blanks that were in my dash previously.
Then I printed up some labels, stuck 'em on and shoved the whole mess back into the dash. Someday I may get to swapping the switches out but for now I press either of these when I'm in low or locking the diff. This kludge re-enabled HDC as well as turns the Lock light on in the cluster.
TRIARII
Mar 11, 2021 02:36 PM
TRIARII
Jan 6, 2017 08:28 PM
philwarner
Mar 13, 2015 09:38 PM
copperdisco
Nov 16, 2013 06:19 PM
bballjames
Feb 22, 2013 08:49 PM
