CDL switch hex size?
Old Mar 13, 2015 | 09:02 AM
philwarner's Avatar
Default CDL switch hex size?
Anyone know what size the hex is on the CDL switch? Metric I assume.
Old Mar 13, 2015 | 09:28 AM
dusty1's Avatar
10mm iirc
Old Mar 13, 2015 | 09:44 AM
philwarner's Avatar
Originally Posted by dusty1
10mm iirc
10mm? It doesn't look that small from the top, but I'll try it.
Old Mar 13, 2015 | 01:10 PM
abran's Avatar
If you are talking about the nut that secures the linkage to the nipple, 13mm.
If the nut and linkage is removed and you want to engage the CDL, 10mm.
Old Mar 13, 2015 | 03:08 PM
philwarner's Avatar
I was asking about the switch that lights the little dash light. Turns out mine was 11/16 for the locking nut, 9/16 for the head, and 3/8 for the body. My switch was toast either before or after I bent the spades with an 11/16 socket, so I put a short 3/8 bolt in the hole until I can get another switch (and not screw it all the way in like the Yahoos who changed the T-case did before I got it).
Old Mar 13, 2015 | 09:38 PM
abran's Avatar
Well, I was no help...
turbodave
Mar 29, 2019 07:22 AM
jfall
Feb 3, 2013 02:16 PM
grandkodiak
Mar 30, 2011 08:06 AM
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
