Replacing Fuel Injector Seals-need advice
Old Jun 4, 2015 | 02:28 PM
  #21
acamato's Avatar
Originally Posted by Alphamale
Andy considering the age of your D2 I would say change the injector seals in any case. I had those dreaded codes too on my 1999 D2 and spent time and money tracking them down. Finally dawned on me that the only place I was over looking was the injector seals. New seal cured everything.
Remove plenum, disconnect the fuel rail and clean area around injectors before removing them. Follow RAVE and remove injectors and their seals.
I found, after breaking one and having to buy a second hand replacement injector, that the heat shields on the end of them is brittle and care is needed in removing the old seals. I decided that it was less risky if I used a sharp craft Knife to cut the old seals off.
With the new seals being a little more pliable it is easier to fit them, but do take care and lubricate them. If you break a heat shield you can't use the injector as the seal will just burn away.
I agree with cutting off the old seals. It's a o-ring retainer not a heat shield. The injector is not in the combustion chamber, so I don't think it will burn up the o-ring. I broke a piece of the retainer off and I have not had an issue 1 year later.
The retainer is replaceable: https://landroverforums.com/forum/di...ld-kits-72596/
Old Jun 4, 2015 | 02:44 PM
  #22
drowssap's Avatar
get MAF cleaner and make sure it is stone cold and do not turn the truck back on until it has completely dried
Old Jun 4, 2015 | 03:36 PM
  #23
Andy2Rover's Avatar
Ok, just finished cleaning MAF with Brake Cleaner after driving the truck home from work (just kidding, I used MAF cleaner on a dead cold Disco). That MAF looked very clean pre-cleaning if that means anything?
Alphamale, I have a feeling those injector seals are gonna get changed, but for $7 and 5min of my time, it's worth a shot at cleaning the MAF.
Thanks for all the input guys!
Old Jun 4, 2015 | 08:30 PM
  #24
antichrist's Avatar
Given where you live you may need a new fuel rail. When I replaced the injectors on my '95 in '07, which was always a GA car, the cups were rusted enough I could never get them all to seal again.
Old Jun 5, 2015 | 07:01 AM
  #25
MPDano's Avatar
We are fighting the same thing Andy. I too am doing the intake and o-rings this weekend. Tried the carb cleaner and no changes. Not sure why some owners don't realize that 6 of those 8 injectors are buried under the intake and no way to spray them. It did stumble a little when I sprayed under the intake, but barely changed. Either way, age of car, seals get brittle and leak anyways. It's due.
Damn check light is keeping me from registering too.
Old Jun 5, 2015 | 07:34 AM
  #26
drowssap's Avatar
Those of us owner that dont know two of the injectors are covered, have heard of vacuum tubing once again spelled VACUUM TUBING. You slide the tubing under the manifold and spray the cleaner in the tubing
Old Jun 5, 2015 | 07:47 AM
  #27
MPDano's Avatar
FYI, got the intake mani gasket kit on ebay. It's an 8 piece kit which includes the valve covers. Gonna remove the peeling paint off the covers and spray some engine clear over the bare aluminum.
Old Jun 5, 2015 | 09:35 AM
  #28
Andy2Rover's Avatar
Thanks for the input MPDano! What injector seal kit did you get?
Old Jun 5, 2015 | 09:54 AM
  #29
MPDano's Avatar
Off eBay as well. $5.49 shipped for 2 o-rings. I bought 8 kits.
GB Injectors Fuel Injector Seal Kit 8-008
GB Injectors Fuel Injector Seal Kit 8 008 | eBay
Old Jun 5, 2015 | 12:34 PM
  #30
Andy2Rover's Avatar
Let us know how it goes, and if your CEL clears
