Replacing A-pillar trim. Where to put clips?
Old Aug 1, 2018 | 08:24 PM
jamieb's Avatar
Default Replacing A-pillar trim. Where to put clips?
I am replacing the A-pillar trim and am wondering - should I A) put the 3 metal clips on the chassis body and snap the plastic into them, or B) attach the 3 metal clips to the plastic trim and then snap it into the metal chassis? What is the safest way to avoid breaking the plastic trim tabs?
Old Aug 1, 2018 | 08:45 PM
naivedisco2's Avatar
I just replaced my driver side a pillar trim - the original flew off at 55 mph and I somehow caught it before it went into the road. The trim I bought came with the metal clips attached to it, and that worked just fine. Atlantic British has a great install video.
Old Aug 1, 2018 | 10:23 PM
Bom2oo2's Avatar
X1-^,,, clips need to be on plastic trim. (I have done it a couple times).
Old Aug 1, 2018 | 10:42 PM
OverRover's Avatar
100%, the finisher clips need to be pre-mounted to the plastic A Pillar before install.
You might find this video useful > https://www.roverparts.com/resources...llar-moulding/
Old Aug 2, 2018 | 12:41 PM
jamieb's Avatar
Thanks!!
Old Aug 2, 2018 | 03:49 PM
CollieRover's Avatar
Put some grease on the pillar where you attach. Maybe even separate the clips a little. This job is harder than it has to be.
cvhyatt
May 22, 2019 11:24 AM
bcolins
Apr 16, 2019 09:42 PM
zuke
Aug 22, 2018 03:47 PM
DonRW2007
Dec 8, 2013 12:14 PM
SuperiorCarCare
Detailing
Oct 22, 2013 08:25 AM
