Replacing Timing Chain and Gears
2001 SE7 4.0 have everything off. My question is ....is the cam shaft gear bolt a left or right handed tread? Bolt seems awful tight and don't want it to snap on me. Thanks for ANY replies.
ok so I am putting the oil pump gears into the front cover and they appear to be tighter than usual. After putting the plate back on I noticed that they are harder to turn. Is this normal or should I take them out and see if theter are burred edges. The old pump gears were not broken and I did have good pressure. BUT I don't want to have to replace them anytime soon and I figure if it's open throw them in. Any Ideas?? Thanks
Martin Rodriguez
02-25-2014 08:55 PM
