Replacing water pump
Old Dec 6, 2008 | 06:07 PM
herblatham's Avatar
Default Replacing water pump
I'm trying to replace my water pump, but i can't seem to get the fan off that's in front. I've got the wrench that holds the fan in place, but the 3 bolts that are on "pulley?" will not budge for the life of me, is there something else i should be doing to get them off?
98 land rover disco
132000 miles
Old Dec 6, 2008 | 06:44 PM
hazletbassist89's Avatar
Default RE: Replacing water pump
I had to use a huge improvised breaker bar when I replaced my fan clutch about a month ago. I didn't have the special tool either so what I did was clamped a vise grip on the water pump pulley, wedged that against the alternator, and then used another vise grip with my breaker bar/duct tape creation to force off the bolt.
It basically kicked my ***, I'm only like 143 lbs 5'10, obviously not exactly a body builder.
Old Dec 6, 2008 | 08:45 PM
NO nothing special to getting the pully off, the fan clutch is the hard one.
You might need to spray those three bolts with Liquid Wrench and let it soak for a few minutes and then try again.
Put a piece of pipe over the handle of your rachet and get more leverage.
Old Dec 7, 2008 | 07:01 AM
DirtySE7's Avatar
Which pump are you going with? Are you replacing anything else while your at it?
Old Dec 8, 2008 | 08:44 AM
mcneal's Avatar
2nd the liquid wrench...those three bolts are put on with loctite at the factory...did mine last week. had a friend hold thestrap wrenchon thepulley while i used a rachet to get the bolts off. i let it soak in the LW overnight though. good luck
jnwinca
Jul 20, 2012 03:30 PM
discomedic4
Aug 7, 2010 10:12 AM
adwarren78
Jan 19, 2010 05:40 AM
grussell
Sep 2, 2009 11:54 PM
jwfuller
Sep 25, 2007 04:46 PM
