ReStarting bad MAF story .....
Old Dec 2, 2014 | 06:01 PM
davecason's Avatar
Unhappy ReStarting bad MAF story .....
Hi Guys,
Ok., so here's where we are now .....
- New second MAF
- New coil packs for all 8
- Four New oxygen sensors
- Eight new plugs
So it's happier now but I'm still getting P1414 and P1417 ?
Any more suggestions? The old codes were:
1st set- P1412 - P1884 - P1415 - P0102 - P1172 - P1175
2nd set- P0102 - P1175
3rd set- P0175 - P1415 - P0174 - P0102 - P1884
4th set- P1884 - P0102
New MAF (no longer daily codes - now occasional)
5th set- P1417 - P1412
6th set- P1414 - P1417
Cheers'
Dave
Old Dec 2, 2014 | 06:15 PM
Kenso's Avatar
Those are codes for the secondary air injection system so not MAF related. I don't have SAI on my truck so I'm not familiar offhand with the typical faults/failures, but SAI issues in general seem pretty common from posts I've read in the past. I would see what the RAVE says about those codes as far as how to proceed in diagnosing the system from here.
Here's someone with a similar issue on another LR forum due to a loose vacuum hose.
P1412 and P1417 solved - Land Rover Forums : Land Rover and Range Rover Forum
Hopefully someone with more experience on the SAI system will chime in.
Old Dec 3, 2014 | 05:38 PM
davecason's Avatar
Default Thanks !
Hi Kenso ...
Thanks for the info ..... I'll start digging around for a bad hose ....
Cheers'
Dave
Piranhaboy
Oct 30, 2013 07:57 AM
herblatham
Apr 12, 2013 11:13 AM
buick215
Dec 8, 2010 09:14 AM
drayrover
Sep 21, 2010 09:44 PM
jkid
May 16, 2008 08:55 PM
