Stalling Out- Troubles Restarting
Old Aug 23, 2010 | 04:17 PM
drayrover's Avatar
Unhappy Stalling Out- Troubles Restarting
I came across an unusual problem the other night, I was driving home and my 03 Disco stalled. I tried restarting it and would just keep turning over but not fire. No problem, A friend came and picked me up and took me home, it was 2AM and Im not going to look at it on the road. The next morning I went to my truck and it fired right up, no problem drove it home. Later in the day I needed to get some groceries about 10miles away. I made it about 2 before stalling out again. Same problem after that, wouldnt start. Walked home called a friend and 30min later we decided to take a stroll and walk to my Disco. Jumped in and after sitting 2hrs, fired right up. Drove home and once again stalled but only 2 houses down. This is really frustrating and esp because I just did alot ALOT of work to it. (O2 sensors, catalytic converter, Head gasket, manifold gaskets) It took me 6 weeks to accomplish all with fitting in tidbits of time here and there. I want to Drive my Disco AGAIN!!! Please help with any insight. After looking thru a couple of posts there is mention of either fuel issues or that of a crank sensor? But i had a new fuel pump put in back in 08. My truck has 84k miles on it. Thanks again!!!!!
Old Aug 23, 2010 | 05:39 PM
sloan74's Avatar
Yup could possible be a sensor/valve (let's hope!). Could be the Crank Shaft or Idle Air Control. Esp the way you are describing. I replaced an IAC valve on a old Ford Ranger, had somewhat the same symptoms. However, it never stalled though. Just a pain in the *** to start. hmmm
________
Digital Vaporizers
Old Aug 23, 2010 | 05:56 PM
bosshogt's Avatar
Those are classic symptoms of a crankshaft sensor.
Replaced mine @ 64,000 on my 2003 as preventative maintainance!
I bet that is the dealeo
Old Aug 23, 2010 | 06:06 PM
bmw zhp's Avatar
ha another sheboyganite...... sorry i cant help you with youre problem though
Old Sep 20, 2010 | 11:35 PM
comido's Avatar
4wd High
I am having similar symptoms. Did you figure out what was wrong?
Old Sep 21, 2010 | 01:49 PM
ROVERTECH15's Avatar
you have a bad crankshaft sensor buddy.replace it and your truck will be fine
Old Sep 21, 2010 | 09:44 PM
comido's Avatar
4wd High
Thanks!
davecason
Dec 3, 2014 05:38 PM
Piranhaboy
Oct 30, 2013 07:57 AM
bmonkey4201
Jul 8, 2010 08:00 PM
bmonkey4201
Jul 6, 2010 12:26 PM
Rover5150
Dec 10, 2007 07:55 PM
