Restoring Interior Plastic Project
Old Feb 20, 2017 | 07:08 PM
LR03NJ's Avatar
Default Restoring Interior Plastic Project
Well got some time to do the headliner. While waiting for it, I decided to restore some beatup plastic panels etc.
Removed headliner.
Old Feb 20, 2017 | 08:14 PM
chubbs878's Avatar
What's all that Crap in the back?
Old Feb 20, 2017 | 08:50 PM
LR03NJ's Avatar
Essential crap! Need to install my MacPro editing sytem back once I get the headliner.
Old Feb 20, 2017 | 09:10 PM
Luckyjayb's Avatar
Looks good. Did you use rattle can for vehicle interiors or regular plastic rattle can
Old Feb 20, 2017 | 09:14 PM
Jeff Blake's Avatar
Nice work. I simply gutted it all, haha. So much more cargo room.
Old Feb 20, 2017 | 09:38 PM
KingKoopa's Avatar
Looks good. What paint did you use?
Fyi, for those plastic parts that start to get brittle and fade, you can soak them in synthetic motor oil and they will regain their elasticity and loose the milky faded color
Old Feb 20, 2017 | 09:44 PM
LR03NJ's Avatar
Her is the paint.
Old Feb 21, 2017 | 12:13 PM
Crisis In My Nomex's Avatar
Looks great. Did you have to do any sanding, or does the paint fill in small gouges?
Old Feb 21, 2017 | 12:21 PM
LR03NJ's Avatar
Do not sand any factory textured panel. You can apply that spray first, let dry then use a (sand) textured paint, then re apply final coating. For upper trim, use fine sand textured spray and for those lower black binsand trim, use medium sand texture before applying final coat. If peeled surfaces, use contact cement, apply both sides and let completely dry before sticking both together. Then apply sand texured paint by brushing it with a small tip brush along the edges.
Old Feb 21, 2017 | 02:23 PM
OffroadFrance's Avatar
Right LR03NJ, mine is in some need of a spruce up internally, oh and externally also, soooo, you can have free accommodation in France and do mine as well.
