Rev Counter
Old Feb 27, 2006 | 02:23 AM
MilitantGrunt's Avatar
Default Rev Counter
Is anything after 3.5k RPM purely esthetics? I never seen the car change gear above that.. Unless I have a problem I dont know about. If its not a problem... my question is why? haha.
Old Feb 27, 2006 | 02:30 AM
mikemeyer0's Avatar
Default RE: Rev Counter
Are you saying why does the tach go up to 6 grand???
I had mine up to around 5200rpm then the rev limiter kicks in, hahaha.
Old Feb 27, 2006 | 02:36 AM
ORIGINAL: mikemeyer0
Yeah that is what I mean, 5200? How.. keeping the auto tranny in 3rd? The auto tranny never shifts at higher than 3.5.
Old Feb 27, 2006 | 02:38 AM
mikemeyer0's Avatar
ORIGINAL: MilitantGrunt
keep it in a gear, start in first, floor it when it gets to 5200 rev limiter will kick in, the rpm will continue to go up that high in any gear.
I don't advise you to try this, 5200 rs is a little rough on this motor, but yes the rev limiter is set close to 5200
Old Feb 27, 2006 | 03:38 AM
MadBilly's Avatar
My tachometer stopped working, What do yall think the prob might be?
Old Feb 27, 2006 | 03:27 PM
haha, true especially that I have close to 97k on the clock now.
Old Feb 27, 2006 | 10:10 PM
NHESS81's Avatar
Hey, if your tach is at zero it is likely that your alternator is about to fail. This happened to me, and seems to be a common problem.
In regards to the level that the tach goes to, it is possible to get your vehicle to shift high, just do what they said. It is helpful when you are in say, 1st gear on the main gearbox and low range on the transfer case, the engine will go this high. Just driving it on the road should never really get over 3.5 at most--if it does, you better be on a hill, or just accelerating way too fast for these monsters. Most automatic vehicles have a tach that goes to about 8000, but the rev limiters hit around 5500-6500. I think the main reason is just parts interchangeablity, very rare Discos exist that are manual, and in a manual transmission you will go higher than an auto. Also, these are high compression, high torque engines, and as far as I know this means that they operate at peak output at a lower range, which is why its so easy to speed in a Discovery, the tach is low and the engine is just humming along, whereas in most cars you can see the engine straining to keep up. I dunno, thats my theory!
vllageidiot
Nov 12, 2014 02:51 PM
Strilciw
Oct 15, 2013 05:15 PM
mitsi88
Sep 24, 2009 08:37 AM
v8man1
Jan 22, 2008 10:49 PM
hollyw
Jan 28, 2005 09:47 PM
