Reverse light issue on one side low voltage
Old Jun 16, 2023 | 05:20 AM
AinaRover's Avatar
6th Gear
Default Reverse light issue on one side low voltage
Aloha Guys,
getting my safety check done and one of my reverse lights (drivers side) is not working.
Found the positive wire broken behind the light in the bumper reconnected with a waterproof connector and still nothing.
Tested voltage at the splice and am only getting 1.6v when in reverse, checked the running light and am getting 12v. Aslo tested with ground on body and still only 1.6v
Pretty sure these are on the same circuit and the passanger side reverse light is working fine. Traced the wire up next to the rear ac and everything looks ok.
where shoukd I check next?
Thanks for your time.
Old Jun 16, 2023 | 12:04 PM
Harvlr's Avatar
I think you’re on the right track. Do you have the wiring diagrams? If not, check out WaltNYC’s posts. A link to the LR manuals is in his signature. The LR Manuals are very good.
Old Jun 17, 2023 | 04:44 PM
WildPackofFamilyDogs's Avatar
What year is your rover?
Salgriffin
Aug 14, 2021 01:39 PM
Llamasayswhat
Jun 5, 2019 08:21 PM
zuke
Nov 10, 2016 08:40 PM
peterh
Jul 30, 2014 03:06 PM
