Reverse wire under console
Old Jul 15, 2016 | 08:12 AM
04duxlr's Avatar
The green and yellow (GY) wire supplies power to the switch, and a green and brown (GN) wire supplies power to the BCM, mirror and lamps when the switch is closed (vehicle in reverse). The GY wire is always hot. I tapped into the GN wire under the console at connector C0681 for my camera. I added a low amperage fuse in the line while I was at it because that circuit is protected by a 15 amp fuse which is a bit big for the light wire used by the camera.
Old Jul 15, 2016 | 08:37 AM
number9's Avatar
Have you looked into using wire at the Park Distance Control ECU connector? Looks like there may be a reverse only powered circuit going back there. If it'd work much easier than running another wire the whole distance.
Edit: Misunderstood need for circuit going to monitor for switching mode rather to power the camera only in reverse.
Glad you got it working as advertised.
Old Jul 15, 2016 | 12:33 PM
JoeLena's Avatar
Thanks guys, everything working great now.
Old Jul 18, 2016 | 03:45 PM
mln01's Avatar
Joe, just where and how did you end up tapping into the harness?
Old Jul 18, 2016 | 03:49 PM
JoeLena's Avatar
I tapped under the console as suggested. The green/brown wire. It was easy to run the reverse wire up to the unit that way. In the rear I used the wire right where it went into the reverse light since my camera is inside the bumper. Works flawlessly now and quite happy. Get you all some pics in a day.
Old Jul 18, 2016 | 04:53 PM
squirt's Avatar
For what it's worth, I tapped the same wire just off the BCU in my 2003. It was an easier run, as I didn't need to remove the console, just the cardboard cover under the glovebox.
roverwoody
Audio/Visual Electronics
Feb 11, 2014 01:18 PM
rezzrover
May 7, 2013 06:02 PM
Evian
May 3, 2008 05:10 PM
zracin
Feb 21, 2008 03:39 PM
