Reversing coolant flow
Old Mar 17, 2011 | 03:31 PM
DiscoBenjamin's Avatar
Default Reversing coolant flow
I currently have no overheating problems, although i may and not know it with the lack of sensitivity that the standard temp gauge has, but recently i have been getting the Waterfall sound.
1. I have read recently about reversing coolant flow to get the air out. Is it the hoses to the reservoir that you disconnect and switch, or something else?
2. Is it better to be a bit over the cold fill line or a bit under?
Old Mar 17, 2011 | 03:54 PM
Bundu's Avatar
Banned
1. You reverse the hoses for the heater core... but this is not necessary if you bleed the cooling system.
2. I don't think it really matters, you don't want to overfill and you don't too little in - the level they give is just fine. Some bright engineer thought that was the right level for some good reason.
Old Mar 17, 2011 | 05:12 PM
yloDiscoII's Avatar
1. Bleed the system ---> https://landroverforums.com/forum/sh...ad.php?t=23072
2. Fill it to the cap (per DiscoMike)
Old Mar 17, 2011 | 11:30 PM
kcabpilot's Avatar
After doing my head gaskets I filled the system via the expansion tank with bleed screw removed then topped off with a small funnel right into the bleed screw orifice. I ran it for about a minute then removed the screw and topped off again. It seems to have worked fine, no gushing and level has remained constant for about two weeks now.
lr2001silver
Aug 22, 2012 12:25 PM
Diverjohn
Feb 9, 2011 01:42 PM
Diverjohn
Nov 11, 2010 03:53 PM
shadrak1960
Apr 2, 2009 10:45 AM
scottiedoo1975
Freelander
Nov 8, 2008 08:13 AM
