Rhythmic clicking noise from the WABCO box
Old Dec 13, 2020 | 10:24 AM
nashvegas's Avatar
Or just buy an ebay SLABS box from a non-Air/non-SLS truck and swap it in.
Old Dec 13, 2020 | 10:34 AM
mln01's Avatar
Yeah, I meant to add that idea too but hit the SUBMIT button too quickly. They're inexpensive. The only problem I see with that idea is confirming the SLABS you are buying in non-air/non-SLS.
Old Dec 14, 2020 | 09:16 AM
Dlueck's Avatar
Thanks guys, I'll dig around and see if I can find one. I know there are a few DS2s at junkyards in KC, I'll start there and ebay and see what I can find. Just to clarify, is it the "SLABS ECU" (64-17 in the manual) that I need to replace?
Is there a way to verify that a used box will work?
Old Dec 14, 2020 | 09:59 AM
mollusc's Avatar
Really, the only way to verify that it works is to plug it in.
I guess you will also have to visually confirm the rear suspension on the donor vehicle as well. I believe that the ACE system may also be controlled by that unit so you should check to see that the donor doesn't have that.
rc51boss
Nov 4, 2022 07:03 AM
gribur
Mar 14, 2014 04:00 PM
crainface
Mar 26, 2009 10:38 PM
jh063078
Feb 19, 2008 10:20 AM
darlo14
Jan 21, 2007 12:17 PM
