Right Rear Brake Dragging
Old Aug 3, 2013 | 09:45 AM
SantaCruzRoverGirl's Avatar
Unhappy Right Rear Brake Dragging
My right rear brake was smoking, had my brakes, disc, calipers, flex hose replaced, on test drive brake still dragging and smoking, need some suggestions!
Old Aug 3, 2013 | 11:16 AM
Mechanic did not finish the work. Flush entire system with 2 quarts of DOT4 fluid. Would be unusual for it to be any parts you have not mentioned, but the system also depends of the ABS modulator to act as electronic brake distribution, putting different power to front or back axles. In old days we had a proportioning valve.
So if a flush doesn't get out any trash, the ABS unit may need examination.
Pages from shop manual for your review are attached. Whole manual is called the RAVE, and is a free download.
File Type: pdf
Old Aug 3, 2013 | 11:49 AM
Call the shop and have them pay to tow your truck back in and fix it.
Old Aug 6, 2013 | 08:14 AM
Thank you for the great suggestions.
Broken08
Apr 3, 2022 10:27 AM
jbkroh
Mar 29, 2014 02:05 PM
DiscoIsNotDead
Oct 15, 2011 01:31 AM
sjewell
Oct 12, 2011 11:20 PM
GregHaugen
Feb 23, 2007 06:42 PM
