The Right Stuff
For the engine, I prefer to use the original gaskets with no gasket makers. The only place I used sealant was the valley pan edges and the oil pan rear bearing cap area (either Right stuff or ultra black oil resistance). I do use Permatex high tack gasket sealant to dress the paper gaskets (including timing cover, throttle body, valve covers, etc).
If I had to use sealant on the timing cover instead of the paper gasket, I would use Permatex Anaerobic Gasket maker (it's red, in a blue bottle) because it is a tight fitting machined surface and the sealant won't harden in the presence of air, so it won't gum up the engine with RTV. I used this stuff exclusively for the transfer case, and so far so good.
