The Right Stuff
Old Aug 13, 2018 | 11:13 PM
User's Avatar
Default The Right Stuff
So I've heard of the right stuff by Permatex being used for the oil pan, but how about for the timing cover?
Mine is leaking, and looking at the thin new paper gasket I can kind of see why.. So if it is such good stuff, has anyone else used it for the timing cover?
Old Aug 14, 2018 | 04:43 AM
shanechevelle's Avatar
I use it for everything.
Old Aug 14, 2018 | 09:28 AM
ahab's Avatar
I use this stuff for anywhere there's a metal to metal joint that uses a paper gasket.
Old Aug 14, 2018 | 12:36 PM
Jeff Blake's Avatar
For the engine, I prefer to use the original gaskets with no gasket makers. The only place I used sealant was the valley pan edges and the oil pan rear bearing cap area (either Right stuff or ultra black oil resistance). I do use Permatex high tack gasket sealant to dress the paper gaskets (including timing cover, throttle body, valve covers, etc).
If I had to use sealant on the timing cover instead of the paper gasket, I would use Permatex Anaerobic Gasket maker (it's red, in a blue bottle) because it is a tight fitting machined surface and the sealant won't harden in the presence of air, so it won't gum up the engine with RTV. I used this stuff exclusively for the transfer case, and so far so good.
Old Aug 14, 2018 | 01:47 PM
ahab's Avatar
To clarify, I still use the paper gasket but the aviation sealant not only keeps the gasket from moving around on assembly it also adds a moisture barrier. RTV is not advisable since if it gets into the exhaust stream it will ruin your O2 sensors.
Old Aug 15, 2018 | 12:23 AM
User's Avatar
Well, I ended up using the paper gasket today. Then I discovered a stripped thread for the oil cooler line.
I'll have to use another cover that I have laying around after I check the oil pump. I may use The Right Stuff to install it, if my new gaskets do not come in tomorrow or Friday.
jackyak
Apr 30, 2018 11:24 AM
lrjon
May 11, 2015 03:00 PM
Cap-n-Cray
Apr 15, 2013 09:34 PM
discofrost
Apr 15, 2012 07:55 PM
discofrost
Apr 15, 2012 09:40 AM
