Right Turn Signal Not Working....? (LOST!)
Old Nov 4, 2024 | 10:56 AM
02Disco2's Avatar
Unhappy Right Turn Signal Not Working....? (LOST!)
Hey,
So I have poked around the forum here a bit to see if I can find an answer to no avail. So, here we go.
Yesterday, I had no turn signals and no hazards. I poked around, not a fuse issue (all fuses are fine). Not a bulb issue as I converted to LED years ago, causes the signals to flash "quickly" but never had a problem.
I started to play with the relays under the steering wheel and was able to get the left turn signal to work. Still no hazards and no right turn signal. I thought that the relays were bad, but I swapped right for left and left for right thinking that the right would start to work. Turns out, the left still works, right does not. So, must be wiring? Checked the wiring on the panel and seems all good. I checked with a volt meter to see if there was a connection issue. All good. So... I am lost!
Anything would help!
Old Nov 4, 2024 | 01:09 PM
JohnZo's Avatar
Maybe try regular bulbs. LEDs are long lasting but can fail.
By the way, there are load resistors available for LEDs that make them flash at normal rates. Is there a flasher module? Maybe it got tired of all the fast flashing.
defenderobx
Defender
Sep 27, 2022 08:31 AM
defenderobx
Aug 5, 2022 01:55 PM
Socialdisturbance
Dec 22, 2013 01:17 PM
Gerard
Mar 1, 2013 01:20 AM
LordOphidian
May 30, 2006 03:00 PM
