Ring with Hayden 2991 fan clutch
Old Jul 31, 2025 | 05:37 PM
keninnc's Avatar
Default Ring with Hayden 2991 fan clutch
I just got the Dorman 620-112 Fan Blade and the Hayden 2991 Fan Clutch.
I was not expecting to find a metal ring with the fan clutch.
Seems if the ring is installed it will be a very tight fit for the 36mm wrench to get in there when removing it if you also want to use the tool that holds 2 of the bolts steady so you can get leverage with the 36mm wrench.
From past experience, is the ring necessary or don't use it?
Old Jul 31, 2025 | 05:50 PM
Best4x4's Avatar
No Ring
Old Jul 31, 2025 | 06:42 PM
Extinct's Avatar
Neversieze on the clutch hub threads and you will never need the holding tool. Don't tighten with wrench, airflow keeps it tight.
SurfinTillTheEnd
Feb 17, 2022 11:09 AM
Spike555
Jul 21, 2016 08:07 AM
CollieRover
Jul 16, 2016 01:51 PM
Scharfire
Aug 30, 2012 06:36 AM
geoffthepoolguy
Jul 27, 2010 05:06 PM
