Road Trip ready?
Old Jun 2, 2011 | 11:01 AM
DarylJ's Avatar
Originally Posted by LRDiscoII1974
the previous owner had just recently replaced all the head gaskets..so I don't know if it is actually leaking, or just remnants from when it was
You're going to have to do a lot better job of describing what you are talking about.
Old Jun 2, 2011 | 11:56 AM
LRDiscoII1974's Avatar
3rd Gear
The previous owner replaced the head gaskets. However, I had a mechanic tell me that it is not out of the realm of possibility that there may still be oil or coolant from when they were originally leaking. That being said, I do not know if when the job was done, the oil that was already there was actually cleaned up. My engine doesn't run hot or anything, it is always in the normal temperature range, even when under duress. So, I don't believe there is a coolant leak. But then again...I am not a mechanic, and was hoping you guys could shine a light on anything. I hope that makes sense
Old Jun 2, 2011 | 12:05 PM
drowssap's Avatar
just for peice of mjnd you might want to ask your machnic to preasure test the system for you or I think any of the big store will let you borrow a preasure test just to be sure it is not coolant.
Old Jun 2, 2011 | 09:44 PM
LuvToDisco's Avatar
Originally Posted by Frank4
Roll the dice man.
This. Pretty much explains it....
FlyingZebra34
Sep 13, 2013 11:34 AM
94svt50
Apr 13, 2012 07:52 AM
Disco Fuego
Oct 20, 2009 05:29 PM
landroverstreet
May 21, 2008 10:57 PM
Bluejayranger
Jul 7, 2007 07:23 AM
