Roof rails vs gutter rails
Old Jul 29, 2015 | 11:18 PM
Womble's Avatar
7th Gear
Default Roof rails vs gutter rails
Is it better to put roof bars onto the gutter rails or onto the existing roof rails? I'm concerned the roof will leak if the roof rails become loose through wear & tear. They're the smaller diameter rails rather than the ES Premium type.
Old Jul 30, 2015 | 12:03 AM
acg's Avatar
acg
I have not had problems with either the gutter rails or roof rails mounts.
Do you have the pre-2004 model (smaller cross-section rails) or the 2004 model (with the sturdier round roof rails)?
Old Jul 30, 2015 | 12:27 AM
Womble's Avatar
7th Gear
It's an 04 Pursuit, but with smaller diameter rails. I'm fitting a kayak (20kgs) & two mountain bikes; so probably hit near the 50kg limit for roof rails.
Old Jul 30, 2015 | 12:46 AM
Joe Btfsplik's Avatar
Womble:
just remember that the manufacturers recommended maximum load for the roof rails assumes the worst case scenario; emergency braking, sudden emergency maneuvers or things that will add extra loads to the roof rails while driving. They are probably strong enough for quite a bit more than 50KG without causing any damage - unless you run into any of the abovementioned issues on the road.
Old Jul 30, 2015 | 01:58 AM
Womble's Avatar
7th Gear
Hi Joe. Was thinking that but it was the risk of harsh braking and rough roads constantly vibrating down through the roof mounts concerned me
austinlandroverbill
Jul 24, 2015 12:00 PM
dbeard
Apr 28, 2015 08:40 PM
Clarkee1973
Apr 3, 2015 08:47 AM
tonyro
Nov 1, 2013 02:37 PM
XCELLER8
May 23, 2011 01:32 PM
