Rotating spare tire in the mix: will it kill my differential or transfer case?
Old Nov 16, 2015 | 11:52 AM
Broken08's Avatar
Default Rotating spare tire in the mix: will it kill my differential or transfer case?
The spare has about 20k fewer miles on it and clearly has more tread on it, maybe a quarter to half inch taller when side by side.
So how bad is it to rotate in to the mix at this point?
I know some cars are super sensitive to even small differences in tire sizes causing transfer case failures.
Old Nov 16, 2015 | 12:09 PM
Alex_M's Avatar
I wouldn't risk it. From what I've read, these Discos are some of them with more sensitive transfer cases and that's a LOT of tread difference.
Old Nov 17, 2015 | 12:48 PM
WNYErikDiscoII's Avatar
Former Sponsor
You'll be fine. As long as you aren't running 3 - 33" tires and 1 - 31" or something drastic like that, don't lose sleep over it.
Old Nov 17, 2015 | 01:25 PM
ZGPhoto's Avatar
Not an issue.
Old Nov 18, 2015 | 10:29 AM
Broken08's Avatar
Thats 2 to 1 for those keeping score. Bump for more
Old Nov 18, 2015 | 11:10 AM
Alex_M's Avatar
If Zack and Erik say yes, then I'm changing my answer to yes. Those two would know.
Old Nov 18, 2015 | 11:23 AM
Dave03S's Avatar
So it would be equally a non issue if i were to use a 255/65R16 for a spare when I get new tires which will be 245/75R16?
I'll probably eventually buy a new spare but in the mean time I won't kill my Tcase if I had to actually use the spare?
Old Nov 18, 2015 | 12:48 PM
Former Sponsor
That would definitely be an issue. You are talking roughly a 1.5" difference at that point.
Attached Thumbnails Rotating spare tire in the mix: will it kill my differential or transfer case?-tires.jpg
Old Nov 18, 2015 | 01:44 PM
Dave03S's Avatar
Thanks, Erik... I'll buy 5.
Old Nov 20, 2015 | 10:08 AM
Broken08's Avatar
So how much difference is too much? I'm debating going out and measuring mine with paint and roll test.
How would I know if it was starting to cause a problem?
I'm on 275/65/16 Duratracs fwiw
