Roto Flex part #
Old Oct 17, 2007 | 05:20 PM
Randy P's Avatar
Default Roto Flex part #
Does aftermarket make a Rotor Flex? I'm looking at this for a vibration issue on accel up hills 40-45 goes away after that.
U joints are all new, flex joint is soft. I can almost make the bolts touch tip to tip when felxed!?
Is it supposed to be this soft?
Old Oct 17, 2007 | 06:00 PM
Default RE: Roto Flex part #
How many miles on your truck, does the roto flex have cracks between the 6 bolts? After market roto flexes are junk and wear out quickly. Might want to buy one from Rover Connection.
Old Oct 17, 2007 | 06:20 PM
Randy P's Avatar
no not cracked at all, just more flexible then I expected.
Old Oct 17, 2007 | 06:44 PM
Normally the disk will last at least 80,000 miles or more so if you still have a vibration I would check the front drive shaft and make sure all 3 u-joints have greae fittings.
Paul Grant
Dec 11, 2011 05:50 PM
Paul Grant
Nov 14, 2011 08:03 PM
hunter
May 17, 2011 08:04 AM
Paul Grant
Apr 15, 2011 07:39 AM
Spike555
Jun 2, 2009 11:19 PM
