Rotoflex with 3" lift?
I have a 3" lift (installed this weekend and last night) and it looks pretty awesome. I'm excited to see the difference. I am rebuilding my driveshafts, but from what I've been reading, there is a significant issue with using a rotoflex rear driveshaft with the lift. I'm trying to keep things low cost, now, after adding up the bills for some of the part orders.
Questions to consider:
-Is this true or can I just be happy replacing the rotoflex and rebuilding the shaft?
-Do I need to replace the driveshaft with a different kind and put a 4 bolt flange on the rear diff?
-If I do put a 4 bolt flange on the back diff, what stock driveshaft should I get?
-Will I need a driveshaft spacer to counteract the greater radius of travel in the driveshaft?
-Would anyone be willing to share experience with this?
PS - do all these checks and measurements on a flat and level garage floor otherwise any results are meaningless.
I couldn't find a $180 rear shaft from Lucky 8. theirs was $900! I'm still looking, though, because I don't want to buy a new rotoflex to just replace it a few months later. I might look at what parts are needed to do a conversion to a cardan or double cardan driveshaft, and if there is one that already exists that would do the job, see if I can buy it used, and rebuild it.
TheWhiteRover
09-12-2014 08:57 PM
DooFlotchy
12-04-2011 05:09 AM
