Rotoflex - which is the correct orientation
Old Dec 9, 2017 | 07:19 PM
elboy0712's Avatar
Default Rotoflex - which is the correct orientation
So I am trying to confirm if I put my rotoflex in correctly when i replaced it. Searches online show both. I have replaced both shafts and the rotoflex and still have vibration. Wondering if i put it in wrong. So of the two photos which is correct?
Old Dec 9, 2017 | 07:24 PM
Alex_M's Avatar
Hang on. I've got a flange sitting in my garage with the donut still on it. I'll post a picture.
Old Dec 9, 2017 | 07:36 PM
OverRover's Avatar
The first pic is correct.
Providing you bought a GKN Rotoflex you will see arrows pointing which way the bolt goes in.
Old Dec 9, 2017 | 07:45 PM
Alex_M's Avatar
Here you go.
Old Dec 9, 2017 | 07:56 PM
elboy0712's Avatar
Default Thanks guys
I think mine is in wrong. Thoughts on using lock nuts on these?
Old Dec 9, 2017 | 08:03 PM
OverRover's Avatar
YES of course use lock nuts on a Rotoflex!!! All Metal or Nyloc Grade 10 ( I would use the all metal), but just use them for sure.
> PLEASE DON'T BUY LOW GRADE or CHEAP HARDWARE....you WILL REGRET IT!
The bolt is part # FTC4043 and the lock nut is # NV112041L > LOCKNUT M12 PROPSHAFT, RND198, NV112041L - Rovers North - Classic Land Rover Parts
I don't care where you buy the hardware from, but you want parts #11, 12, and 13 in the pic. > Discovery II Prop shaft and U Joint - Rovers North - Classic Land Rover Parts
Old Dec 10, 2017 | 05:40 PM
OffroadFrance's Avatar
Preferably fit new bolts, nuts and washers and insert the bolts in the direction of the arrows on the Rotoflex. Don't forget to torque them up correctly also.
boris_gti
Oct 12, 2011 11:47 AM
grandkodiak
Mar 29, 2011 03:04 PM
wick_60010
May 25, 2009 09:54 PM
MONTANACW
Feb 2, 2007 01:22 PM
tbesselman
Jun 3, 2005 02:42 PM
