Rough acceleration and pulls to right under power
Old Feb 9, 2024 | 04:58 PM
Jamesh007's Avatar
Default Rough acceleration and pulls to right under power
Help, my Disco 2 has always had a shake and bumpiness under acceleration, been trying to diagnose for about 6 mos, so far I have:
changed out wheels tires with my other disco that had no issues and it’s still there
checked prop shafts for play, they are super tight
upgraded suspension (terrafirma) shocks springs and skeleton towers… Still there
its only bad and shows under hard acceleration 3k plus rpm’s and while the rough bumpiness almost always shows, especially at high speeds 70-85 under acceleration only. Today at about 50 under hard acceleration it pulled super hard to the right and I pushed it harder to try to figure it out…. Still no idea, as soon as I back off and re engage normal acceleration it disappears. Almost wish something would break so I can fix it….. motor mounts ? Ball joints ? Bushings ? Any ideas
posted pics of bushings ball joint and mounts
and rear steering arm, possibly slightly bent
Old Feb 9, 2024 | 05:09 PM
Jamesh007's Avatar
Is there way to test motor/trans mounts, seem like a symptom? I can’t seem to get a pry bar in a god spot. More pic’s of mounts attached,
Old Feb 9, 2024 | 05:29 PM
Harvlr's Avatar
You could try a bottle jack under the oil pan. I’d put a piece of wood between the jack and the pan, but the pan is really quite robust on its own.
Old Feb 9, 2024 | 05:56 PM
H20nSnow's Avatar
You have a torn ball joint boot so there is a better than average chance that at least one ball joint is bad. Have you checked the ball joints and CV joints? The ends on the steering rod and tie rod? They can be checked without disassembling anything.
Old Feb 9, 2024 | 06:01 PM
Jamesh007's Avatar
Great idea on the jack! Looks like both motor mounts and at least 1 tranny Mount! Wonder what’s holding the engine and tranny in ? I’ll be looking into checking ball joints too ! THANK YOU
LR disco 5
Sep 15, 2025 01:39 PM
Striker223
Range Rover L405 (Fourth Gen)
Jun 12, 2023 03:24 PM
hasullivan
Dec 31, 2022 10:23 AM
Friday Night Disco
ROAMING WITH FRIENDS
Dec 29, 2018 06:37 PM
fcdrifter13
Aug 10, 2011 03:55 AM
