Rough few weeks with the D2
Old Jul 20, 2020 | 08:45 AM
deodra's Avatar
Default Rough few weeks with the D2
Over the last few weeks, I have been working through some things that have needed attention for a while. The front end started in with an even larger vibration, so I tore into her and ended up needing ball joints (rare, so I hear, on D2's) and the boots on the CV axles were both torn open and there was a little play in them. After a day and a half (about ten hours of actual work) the driver's side ball joints and axle were done. The CV axle was a breeze, but the ball joints SUCK to replace on these!!!! Heat, big F'ing hammer, jaws, press...they finally came out. I hate the design-- I don't own the special tool and since the knuckle is sloped, it was miserable trying to get the top one out. Geez. It was such a misery that I have not even started in on the passenger side. Whilst doing this, I found that the track rod ball joint on the driver's side is worn, too. Now, I have to order that and knock it out.
My question is this: If I order the track rod with attached end AND the drag link with attached end, do I need anything else? That should complete all ends and things that I should replace at the same time, yes? I am thinking these (a combination of) are what's causing my low RPM/speed vibration. Front and rear prop shafts have been replaced. Thoughts?
Old Jul 20, 2020 | 04:38 PM
Richard Gallant's Avatar
No to the track rod and tie rod end, but be very careful of the torque the RAVE is screwed up in one place refer to paged 57-47 through 57-49 for the correct value 59 ft/lbs
Get greaseble if possible and you will need an alignment after.
Rent the separating tool it makes dead simple to do
Old Jul 21, 2020 | 07:57 AM
deodra's Avatar
Thanks! When you say no, maybe I'm daft, but what do you mean? I can't think of anything else I'd need, but I'd love to defer to y'all to verify this assumption. I have a pickle fork and separator jaws, if that's what ya mean. Thanks so much!
Old Jul 21, 2020 | 09:25 AM
zuke's Avatar
Well if you are gonna do all that then you may well replace the steering stabilizer. You will have it off anyway.
Old Jul 21, 2020 | 09:33 AM
deodra's Avatar
Valid point! Thanks!
Old Jul 21, 2020 | 11:19 AM
frostythor's Avatar
Dont forget to get your wheels balanced, one lost weight can make the front wobble, plus you can string line your wheel to puta basic tracking on before you drive it, you must check the drag link side first then the other side other tie bar,
Old Jul 21, 2020 | 11:32 AM
@deodra Sorry about that the no was for no there are no other major things to doing the track rod and drag link, And yes to the separator jaws, I was typing between getting my honey do book done
Old Jul 21, 2020 | 12:12 PM
frostythor's Avatar
Hi if your still not sure if your steering is centred then centre the steering wheel the get underneath, and check the steering box is centre correctly
if the steering box is centre correctly, then a string line across the centre of the rear tyre across the front pulled tight across the centre of the front should tell you if the alignment is of the wheels are equal, as per my earlier post, if they are not equal
you will notice the front is TOE OUT, to Parallel, so once your happy your steering box is central, run the string down the passenger side first to check the drag link is set up correctly, if it is now check the drivers side to see if the tie bar is set up correctly, if this is all OK then any gap at the back of the front wheels should be equal 1 -2 mm, to zero, as shown in my earlier post, finally check to see if your steering wheel in still centred
Old Jul 21, 2020 | 12:19 PM
deodra's Avatar
Y'all are awesome!! Thank you very, very much!!!!
twr7cx
Dec 21, 2018 04:17 PM
Codyt
Oct 16, 2018 10:31 AM
JettsRover
Nov 2, 2017 01:59 PM
chvy383
Freelander
Jan 5, 2009 10:48 PM
Newbie
Nov 13, 2007 09:25 AM
