Rough Idle
Old Jun 15, 2021 | 08:17 PM
jacobmstein's Avatar
Originally Posted by Best4x4
I'd get a cheap spark plug tester from an auto store or harbor freight and check all 8 cylinders for spark. I once had a CPS going out that caused an awful rough idle, but it eventually set a fault code. Only other time I've had an idle like that was a messed up Bosch Purge Control Valve, and a bad coil pack.
I'm currently staying in Sedona, gonna take my car to this Indy shop in Phoenix and hopefully they'll have the parts on hand. I did the diff seal and rear driveshaft in my hotel parking lot. I've had enough for this week in this heat. Hopefully they can fix it and I can get home and back to work. It doesn't sound like somethings wrong inside the engine to you guys?
Old Jun 15, 2021 | 09:19 PM
redwhitekat's Avatar
just wondering about your diff seal. Never heard of one failing that bad. What happen
Old Jun 15, 2021 | 10:17 PM
it started dripping pretty slowly and then after a day of wheeling in Moab it just started dripping out a ton of oil. Breather was melted a while ago, I replaced it. That may have been the cause
Old Jun 15, 2021 | 10:36 PM
nashvegas's Avatar
Hmmm. It doesn’t sound internal to the engine (bearing etc). But I’m not too sure.
I wonder if the diff oil got in the 02 sensor harness... still seems a long shot. But that seems possible. Even with a dead 02 sensor it should run at least semi-decently on cold start in closed loop mode shouldn’t it?
And good luck. You are in the thick of it, for sure.
Old Jun 16, 2021 | 12:11 AM
Dave03S's Avatar
Are you sure someone didn't steal a cat? Almost sounds that loud!
Old Jun 16, 2021 | 10:18 AM
dswilly's Avatar
My thoughts -
With the engine you have two real demons to wrestle - heat & oil pressure. if both of these are in normal range I would give you a 99% chance of making it home. If you have been driving in the Arizona heat without a problem I would think cooling is doing ok.
A walked cam bearing would have an impact on oil pressure I think.
If it makes power and has good oil pressure and decent engine temps throughout the speed and rpm range, go for it.
Old Jun 16, 2021 | 10:27 AM
Best4x4's Avatar
Yeah unless the CEL is flashing I'd drive it especially since it isn't tripping any faults or pending codes. Heck it could be just a cracked exhaust manifold.
Old Jun 17, 2021 | 02:09 AM
The Deputy's Avatar
My first question would be...does your CEL illuminate when you turn the key on? If it works, and you have no codes...l'd drive it. May be a bad tank of fuel. It seems to clear out and run okay off idle, and like mentioned, the excessive noise may just be a cracked manifold or y-pipe gasket.
Old Jun 17, 2021 | 12:56 PM
No CEL, I have an UG too and I even checked pending codes. Took it to an indie (Rov N Tech) in Phoenix and they determined it was failed fuel injector O-rings. Hope that helps somebody and I hope they're right when I get my truck back tomorrow afternoon
Old Jun 17, 2021 | 01:28 PM
matt3502's Avatar
With that diagnosis, I am surprised you are not throwing any codes. That is a pretty simple job if you have the time and a place to do it where it is not as hot as standing on the surface of the sun.
