Rough idle misfire codes P0300 and P0305
Heads and block deck are well within spec for flatness so no need there.
UPDATE: Gaskets replaced and we are back in business. Some valves needed lapping and tightness checked on rockers, push rods, etc. Something must have been loose because the engine is much quieter now and that annoying "tick" has completely gone away. All cylinder sleeves where checked and there was not indication that they moved so that was not the source of the tick.
One curious thing is that my temps are higher than before with the 180 tstat. Was 188 to maybe 205 on a hot summer day, now I am in the 200 to 220 range. Got no trapped air, hoses are correctly attached., no coolant leaks or lose and fans spin when they should....at a loss on this one.
fund247
Feb 16, 2013 02:22 PM
EVN137
Feb 25, 2012 02:05 PM
