rough road sensor?
Old Jan 17, 2007 | 07:44 PM
suntattoo80's Avatar
Default rough road sensor?
where is the rough road sensor on a 00 disco2
Old Jan 17, 2007 | 08:06 PM
Default RE: rough road sensor?
Why do you ask?
There is a code for rough road but I don't believe there is a sensor.
Mike
Old Jan 18, 2007 | 06:17 PM
hoberock's Avatar
For the '97 Disco, my GEMs manual says it in is the ECM... But I an not sure. I have not seen anything about this in my manual.
Tim
Old Jan 18, 2007 | 07:22 PM
geoman's Avatar
Gents,
There is no rough road sensor. The way it works is that when a vehicle is driven over a washboard, potholed, or otherwise crappy surface, there is a resonance that occurs at the ABS sensor-to-target wheel location. If this is high enough in amplitude and the variation in air gap is severe enough it will throw a rough road code that the computer stores. In addition --- the computer programming is such that it will disregard any indication from the engine crank position sensor that normally would trigger a "multiple mis-fire" code --when the resonance is present at a ABS sensor/trigger wheel. This is a safeguard to avoid throwing the Check Engine Light on if the crank sensor itself is experiencing a vibration caused by the rough road conditions.
regards,
Geoman
www.eurotekapg.com
KlamathMatt
Apr 17, 2020 05:27 AM
dillhole
Feb 20, 2020 02:30 PM
ls1morethanyou
Apr 21, 2014 11:14 PM
jimvw57
Mar 8, 2014 04:35 PM
twaszak
Jun 4, 2011 07:49 AM
