Rover is DEAD!!!
Old May 11, 2010 | 06:23 AM
audiS4S6's Avatar
Originally Posted by tornado_735
That Rover dealer is trying to milk the cash cow.
I think that is the problem, it isn't a Rover garage... Even worse!
Old May 11, 2010 | 07:18 AM
I would guess, the mechanic doesn't have a clue what is wrong, and I bet he never checked all 8 holes.
If the compression is gone, that would normally indicate a broken timing chain. I doubt this has anything to do with a possible oil pump failure.
There are a number of things to check and then to do, if you want some direction on this, send me your number and I'll call you.
Old May 11, 2010 | 03:23 PM
03DiscoSE's Avatar
So you're telling that there's a chance the motor isn't toast and I may be be able to get off slightly cheap? I've got a guy that's going to do a leak down test on it once I get it towed from the dealer and hopefully that'll narrow things down a little more. If it was a timing chain, would that damage the valves on this motor?
Old May 11, 2010 | 05:40 PM
greg409's Avatar
That's your best bet.
Have a mech you know check it out.
I've seen a fair share of castastophic motor failures, either it scares the crap out of you or it locks up, but if it cranks over there's compression on at least one cyl.
I don't think they checked it out at all.
$180 should have gotten you more info.
luck,greg
please let us know what happens
Old May 11, 2010 | 09:25 PM
If the oil light came on you lost oil pressure and there is a good chance the cam bearings are shot.
lesliesmukler
Nov 7, 2009 05:23 PM
mylemon
Oct 18, 2009 02:59 PM
Brokenrover
Dec 14, 2007 08:27 AM
CPDieker
Jul 23, 2007 09:22 AM
parpar
Nov 5, 2004 05:14 PM
