RPM's Jumping Between 3k and 4k
Old Mar 3, 2023 | 01:14 PM
TheOnlyTrueWorm's Avatar
4th Gear
Default RPM's Jumping Between 3k and 4k
My 02 Disco 2 has a sudden power loss and rpms start jumping when in between 3k and 4k, and im not entirely sure whats causing. I just recently replaced cylinder head gaskets and the intake manifold gasket and it seemed fine for a bit until this issue popped up out of nowhere. I cant seem to locate the issue as ive tried checking for vacuum leaks, cleaning the throttle body, replacing sensors, etc. Its somewhat on and off but its mainly a constant issue with small breaks of maybe an hour. Any idea whats causing this?
Old Mar 3, 2023 | 07:17 PM
Alex_M's Avatar
Any codes?
Does sound like a vacuum leak. Pull spark plugs and look at them, they will also gove more info. I had an intake on a dodge one time and the vacuum leak was internal, pulling air (and oil) from the valley. Would be very strange, but if all else fails may be something to look into.
I'd want to see some codes and live sensor data.
Old Mar 3, 2023 | 08:30 PM
4th Gear
I shoulda mentioned it in the post but there's no codes, at all. That's part of the reason I'm having such a hard time diagnosing it. Ill check out the spark plugs tomorrow as well and see if I cant get some live data. Thanks for the suggestion!
Old Mar 4, 2023 | 06:53 PM
The_OGCJR's Avatar
If no vacuum leaks, check iac valve and clean it
Old Mar 5, 2023 | 06:52 AM
Alex_M's Avatar
Also, what are you using to check for vacuum leaks? If it's brake clean, I have used brake clean that didn't show anything. I recommend starting fluid to be sure.
I personally doubt IAC because of the missing - IAC air would still be metered and should just idle at the wrong speed without missing. Doesn't hurt to clean though.
mcaz
Dec 31, 2018 03:08 AM
Avery Hindman
Engine & Internal
Jan 10, 2014 03:09 PM
IndyCJ
May 17, 2013 11:16 AM
ESPN
Mar 11, 2013 12:12 PM
2002FreebieSE
Dec 8, 2006 09:14 PM
